the blower motor is working fine, however, it is making groaning sounds, while in operation. The higher the fan speed the more obnoxious its sounds. Any feedback would be greatly appreciated. thanks..........
2010 DTS
I would suspect the bearing is getting dry and will only get worse untill it fails. If it is the OEM blower you can take it apart in place and pull the armeture out. I think you might be able to lube the bearings then. Never really looked when I replaced mine. Just threw it away.
