1997 Deville
Hi, thanks in avance for anyone's help I cleared my and and traction lights finally and I routed the problem down to a bad right rear hub assembly which getting done tomorrow but it snowed smd rained a lot and there's massive puddles and it seems to Newell im fairly certain that when I go thru a big enuff puddle it automatically will throw and and traction lights then they will clear up but it threw a bunch of codes like front driver Hub, c1255 and then there's the always constant c1298 loss of cummunications
And also the current was c1241 variable efforts steering malfunction any ideas of what is possibly causing this I guess water is getting sumewhere and throwing the codes sorry about shitty thread I am driving and writing this im always working
that is VERY dangerous to OTHER victims around you -
why don't you try again - later -
when you are safely stopped somewhere -
and you can concentrate on writing -
PUNCTUATION helps US try to assemble your seemingly random thoughts -
1997 Deville
Okay well I'm sorry my random thoughts are as follows
Abs and tcs lights would illuminate( light up) intermittenly in between the constant service steering system message. I know I need a rest Hub assembly but I don't think that will solve my problem!!
It was wet out( it rained a lot) and as I went thru a hefty puddle, there would be no ses lights on clear dash, it would throw both abs and tcs lights on the dash!!! It was right as the front of the car would enter the puddle!! My assumption is that the water was penetrating somewhere in the engine that would cause this!!! After a minute or so the dash would clear again.
Now my question is if anyone has any incite on a possibility where moisture could be getting in somewhere and throwing the codes.
The codes I had were
c 1241- variable effort steering circuit malfunction which was current( at the time)
C 1298 pcm class 2 data link malfunction which was not current but was thrown recently
These are the two codes I was worried about and think maybe someon could have a opinion on
Sorry for the seemingly random thoughts was having a shitty day and didn't mean to cause the forum any grief or seemingly ******* remarks thank u
not sure what a rest hub assembly is -
only emissions related problems -
illuminate the SES light -
I would expect more "C" codes set - than the two you listed -
start checking the various grounds -
