1997 Deville
Okay I have had a problem with my abs and tcs lights for a long while now, I have replaced 3 out of 4 wheel bearings, all except for driver side hub!! Now all codes have gone away but I am getting like a flutter in my brake pedal when stopping almost like anti lock brakes are pulsating is what it feels like and it shot a brief code of c1225 left front wheel excessive wheel speed variation!! So with that said if I go ahead and replace the driver side Hub will this delete this problem and the code??? Or am I pissing in the wind here?????
yup - bad speed sensor in the hub -
we recommend ACDelco or TIMKEN hubs -
Check the electrical connections for cleanliness or moisture first - those wheel speed sensors each go to a main body harness - the pigtail connector sometimes loses continuity or gets corroded.
