Bristle brushes, old toothbrushes, block the butterfly open and use a rag stuffed into the TB past the butterfly to the manifold side (pull it out with long needlenose) and throttlebody cleaner, not carb and choke cleaner. Different chemicals.......
Anouther thread on a little different subject than the ELC problem.
So far not getting the back seat cushion out to get to the ECL relay, so I decided to clean the throttle body while I rested, I had done this a couple of years ago but would like to ask advise on the best way to clean the mouth of the intake.
The butterfly housing assem. came nice and clean with carb cleaner, but the intake mouth has thicker harder varnish residue.
Is there a brush or tool or !~!, that some of you have used?
