1996 Fleetwood Brougham
My Fleetwood Brougham wobbles down the road (much more noticeable at low speed) and the steering wheel seesaws. I'm diagnosising that as a bent rim up from.
These wheels can't be unbent, can they? Where do I find a replacement? The only ones I found on ebay were a complete set for $2,000 or so. I just need one wheel in driver condition.
THANKS!
2011 Escalade ESV
Not sure about the replacment, but I do know from experience, that you can get the same exact action from a bad tire. My 75 was doing the same thing only in the rear. I would have sworn it was a bent rim, as a matter of fact I was in search for one. Then one of my front tires came apart so I went and had a set put on all the way around.....smooth as a button now. Good luck with what ever it is.
Didn't even think about that.
I'll have to look at the tires more closely.
thanks
2011 Escalade ESV
yeah my tire guy said that mine had seperated pretty severly. I wasn't REAL obvious until he pulled it off the car and took a close look at it.
2014 ELR
A 15" alumininum wheel with a 70 or 75 series tire is just about impossible to bend. My bet is on a separated belt on a tire, or worn steering (center link or idler arm).
Simply jack the car up and spin the front tires by hand. Its a failed belt in a tire I'm guessing.
