1 - 20 of 24 Posts
96 CADILLAC FLEETWOOD BROUGHAM
Low coolant light on, i topped off the overflow tank because it was low, so how do i get rid off the low coolant dash light? Or does it go off by itself? Any input please
Discussion Starter #2
I see the temp light kinda on? Meaning it not super red but medium red? Weird? I had replaced my thermostat due to over heating threw overflow tank now its fixed and lost some coolant, i tryed to fill threw thermostat hole but it was already to the top so i let it run a few to get the coolant flowing and the next day i noticed the overflow tank coolant was low so topped it off to try to get the light off so this where im at with it now
2014 ELR
Re: 96 fleetwood low coolant light reset?
Smack it HARD with the side of your fist rapidly. The coolant reservoir. The sensor sticks. Ultra common.
Engine coolant temperature gauges and lights are driven by the ECT sensor in the block or a cylinder head.
Coolant level (OK/low) is monitored by a sensor in the surge/recovery/overflow tank (depending on cooling system type).
There is no interaction between the two.
Unless there is some system that causes the temp light to glow with variable intensity based on coolant temp (highly unlikely) then a barely glowing light appears to be a bad connector, chafed wiring, or faulty temp sender.
That info would, along with the wiring schematics, be in the GM/Cadillac service manuals. www.alldatadiy.com or a paper copy from eBay.
1996 Fleetwood
Re: Temp light?
There is a sensor for the idiot light on the passenger side of the engine near the dipstick. It may have a bad connection, melted wire, or bad sensor. Unplug it and see what happens
Discussion Starter #12
Ok heres my other concern i been noticing on my 96,when i crank up my car at idle maybe 10 minutes my temp light seems like its slowly coming on but not as bright as the other lights on the dash? Does it work itself to get brighter when it gets hotter maybe? And what can cause this light to come on? Im thinking its my water pump but dont want to jump the gun? Any advice
https://pasteboard.co/IaDabmZ.jpg
Is the sensor up above by dipstick or down below
Moderator edit: Your two threads on the same set of problems have been merged into this thread. Let's keep all the questions and advice in one place.Thanks, Sub.
1996 Fleetwood
Side of the block, one wire you can't miss it. Sensor is probably bad, should be on or off.
Sent from my SM-G965U using Tapatalk
Discussion Starter #14
But how does a bad sensor slowly come on when car getting hot? Seems like its working but will try to locate it
1996 Fleetwood
Well mine completely cooked the connector and the wire, but intermittent/poor grounding or a faulty sensor not completely closing a circuit could potentially cause that.
1996 Fleetwood Brougham V4P
Hmmm. My temp light barely glows red all the time. Good to know it's not just mine. Any harm in just leaving it alone?...
1996 Fleetwood
Not that I know of. But then again, after mine cooked the connector, I never fixed it. I like to live dangerously.
Discussion Starter #18
Yea thought that was strange as well,but wonder thats a sign that something is bad right? Why evrybody asume its a bad temp light? I replaced my thermostat and cap, next will be change the temp sensor and if it the light still comes on i think its my water pump or radiator maybe?
Discussion Starter #20
It doesn't overheat at idle nomore, i havent attempted to take it out on a drive due to that temp light comes on slowely at idle after 10 minutes
1 - 20 of 24 Posts
