1 - 11 of 11 Posts
1988 Coupe Deville, 1991 Coupe Deville, 1989, 1994 Eldorado
I just replaced the rack on my 89 eldo... I only use GM delco parts in my cars... you can go to www.newgmparts.com
they have the best prices on GM parts .. they are a GM dealership in Hyannis, Mass. call them and they will give you a price.. or you can search it on their website
hope this helps
jim
eldorado billy said:
Has anybody replaced there steering rack yet on there etc?I have a 96 etc eldo,i need a rack,i am wondering where i can get the best price on a reman rack?
What give you the impression that your rack is no good? I'm wondering about mine lately. What are the tell tale signs?
· Banned
2005 STS4 1SG: GM Acc Lights, Corsa, Platnium Grille, Volant
· Banned
I think the only diiference was between steering is magnasteer which was an option i think in 96 and became standard in 97 not sure tho im sure if you email the seller they can tell you of this can work with your 96 etc goodluck
Discussion Starter · #6 ·
I was told by a mechanic that i had a bad rack.I replaced my struts,bearing plates,and removed the sway bar,and i still have the clunking sound like many other owners have on there etc's.The mechanic said i have play in the rack,he showed me the clunking in the front end,the car was on the ground,he grabbed the front wheel,he was able to make it clunk by grabbing it at 9 and 3 on the wheel.It was not the tie rod ends he was hoping for,but he said it was the rack,yikesssssss.So i have to buy a rack now.
Discussion Starter · #7 ·
I am trying to figure out if i have the magesteer in my car.I bought the car used,so im not sure whats in it,with my luck,i probllay have it.I have the build sheet from the trunk,i could probllay go to a local dealer and ask them.
· Banned
yea thatd be your best bet you should ask check with the guy and see if thats what the difference between the two are it may be more than just magnasteer. My 97 ETC has Magnesteer and Stabilitrak
Discussion Starter · #9 ·
Hi,when i turn the wheel side to side,i get the clunking noise too.I can grab my tire and wobble it side to side and dupilcate the noise too.I am pretty sure i have the magnasteer and stablitrak,i have disabled the stabiltrak by using passive stuts.I can ride down a smooth road,no clunking,then the slightest bump i have th noise.
2008 SRX-V8, 1991 Eldorado
How many miles on the clock? What was the primary area the car was driven, for example city, rural, highway?
1 - 11 of 11 Posts
