My dash lights stays on........even while the car is off......one day they went off & i played with the headlight switch.......then they came back on.......& stays on.........can sombody help me pls...........
Discussion Starter · #4 ·
Thank you Ranger & Basscat for your quick response........I pulled the headlight switch......but the dash lights still stay on........should i replace the whole switch????????.........& also where would that relay be located???????? Thank you...
Discussion Starter · #6 ·
Ok bought a new ign 1 relay that goes under the hood in the fuse box area.......that to was not the problem......so I'm starting to lean towards the ignition switch itself......I did smell a faint burning smell like rubber before this happend......
