So here is the deal:
Purchased my 96' Deville from the original owner with 35,000 in the clock three years back. Since then I have put 4,000 more miles on it. For two years I drove daily for a 2 mile commute. After that stored it for 9 or 10 months. Recently brought her back out, changed oil, filter and fresh fuel. Immediately the AC compressor clutch went and took her off the road. I had a local shop change the compressor, recharge and AC is working well again. I am now however having some overheating issues. On top of that it is running rich but has the whole time I have owned it. When I bought it was hesitant to start so I had the FPR changed which fixed the start but then I started getting terrible gas mileage. I never addressed as but less than 1000 miles on a year.
Symptoms:
Overheated in traffic the other day it was about 85 degrees out. Temp reached 220 and it gave me a check engine light and coolant hot idle engine message. As soon as I got moving again it cooled right down.
Since then it has given me the same code 2 other times under seemingly random conditions.
I performed the highway test of 30-70mph back to 30 up to 70. Stayed cool on the highway then on the off ramp at the light have me the coolant hot idle engine code even though the coolant temp was 202. Every once and while I will get a backfire at cold start but not consistent.
Does seem to be running a bit rougher than usual.
Last night when pulling off a short highway trip it gave me the coolant hot code and then a change engine oil code
At idle the temp seems to fluctuate from 208-222.
Things I have checked:
-Purge line is clear, it is shooting plenty of coolant when running
-No residue under oil cap
-Coolant is not cloudy (it does however have pink coolant in it) I had a it flushed at a shop a few years back and it doesn't look like dex cool
-I can't seem to see a coolant fill line in the surge tank but I am not getting a fluid low code
-coolant doesn't smell like exhaust
-Not getting noticeable steam or condensation from exhaust
-Purchased a block test and tested from purge tank after running for 15 min and engine running - test fluid is dead blue
-Oil level- after I had the ac compressor changes the oil level on dipstick was low I assume bc they took the oil filter off to get at the ac compressor. I added oil and now is near max line after running.
-Water pump pulley seems to running fine from visual inspection, nothing obvious with tensioner
-Pulled the codes and attached a photo
What do I do next? Thermostat? Coolant Flush? Get the radiator tested?
Any help appreciated.
Symptoms:
