1 - 13 of 13 Posts
Emissions system reading across the dash and these two readings popped up. Recently I noticed it takes 6 to 7 kicks to turn over an now sounds like 15 to 20 so this seems like something like a fuel pump not sure any ideas?
Not sure what exactly questions are, post your codes with definitions. If long cranking i woukd check fuel pressure as easy to do. Knock sensors have never been mentioned as going bad here, although my wiring had about been chewed threw by vermin...
Re: 96 sdndeville knock sensor and o2 sensor
:yeah: Fuel pressure (assuming you are talking about cold starts).
When was the TB last cleaned?
Codes were b1 knock sensor and b2 rear o2 sensor. Changed the rear sensor and after about 3000- 3500 rpm the service soon light will pop on. Def goin to try to clean throttle body. Sounds like no fuel at first then slowly will kick over like a 2 stroke.
No such codes.
You're looking for several DTCs that look like P XXXX and/or U XXXX - a letter followed by 4 digits - and then a C or H (Current or History). Your car may use a mix of older OBD1 and newer OBD-II codes: 1996 was the turnover year.
There is no such thing as a B1 (Bank 1) knock sensor. There is only one knock sensor.
Discussion Starter #8
Changed plugs an wires and runs like a top. Cleared the 02 sensor code but yes still just knock sensor code. Once I reach a certain rpm the knock sensor code will pop back on. Seen the fuel rail and stop there. Is this expensive and should I replace the starter as well. Don't read much on knock sensor problems on a N*
Use this to make sure the coils are correctly connected to the corresponding numbered plugs.
:hmm: Why would you replace the starter for a knock sensor or O2 sensor code? If the engine cranks, the starter is good. Chances are, you have a bad knock sensor if you have a knock sensor code.
Ahh, hadn't thought of it that way. I agree. I wouldn't.
1 - 13 of 13 Posts
