STS
Hi!
To make it short: I'm from Germany and since 4yrs a proud owner of a '96er STS. Now "they"have introduced the "new" E10-fuel here in Germany and since it's cheaper than "Super" I wanna know, if I can use it too, without risking to damage my engine.
Thanks for your help and with kind regards!
Dan
2010 DTS
Almost all the fuel in the U.S. is E10 (10% ethanol) and has been for 30 years or better. The car was designed to run on it (check your owners manual). You won't hurt a thing, but might notice a very slight decrease in MPG (or KPG as you might put it).
STS
Aha, interesting! Thank you for your info!
Danni, Your 1996 Northstar is calibrated to run on premium fuels - 90 octane or higher. The engine controls system uses a knock sensor to electronically retard timing a few degrees when spark knock is detected. If the E10 which is being introduced in Germany is above 90 octane there will be no spark retard; if the new fuel is 87 or 88 octane, then it's possible that a bit of retard would be set, reducing engine performance and fuel mileage slightly. For city and quiet driving the E10 would be fine, but if you embark on a high speed Autobahn trip I would use Super.
