1 - 14 of 14 Posts
2016 SRX Performance, 2006 STS 4,
I have a 96 cadillac etc and the air condition has been not been blowing so hard. The air box is cracked near the blower that cover the evap core. Does anyone have any suggestions to fix this? I attached two pictures.
Thank you for your help in advance
1996 SLS / 2005 SRX V8
I covered it with a piece of sheet metal and used the three existing holes with self taping screws.My cover falls apart when you touch it.I guess it was a flaw in design.
2010 DTS
It is somewhat common as the plastic gets brittle over time and heat cycling. Several options have been discussed before. Patching it with aluminum tape is one option. Another is self stick drywall mesh and then coat with RTV. I'd be Leary of drilling and screwing it as it is brittle and may get worse.
2000 Eldorado ESC
Or................ you could replace it with a new HVAC cover (insulator).
Part # 52491785. In any case cover that evaperator inspection hole with anything handy.
Duct tape, piece of sheet metal.
2000 Eldorado ESC
Yes, but I think you could get away with lowering the rear of the cradle enough to change it. Maybe use the threaded rod method like BBF (Mike) did over on Caddy info.
2010 DTS
Good thought. Having never needed to do it, I don't know how much more clearance is needed. Probably would be preferable to a patch. If it deteriorated that bad patching it would be like welding on rust.
Silver 1999 Sedan DeVille (base) 103,000 miles
I have a '99 Deville and the same thing has happened. I was at the junk yard looking at how it would be possible to replace that thing... Man it's a big part. Looks really challenging. But I'm wondering if I just wanted to patch up that little hole. Am I really repairing it? I mean is the whole thing a metal container covered by foam and plastic with this little access hole?
Any advice would be helpful, Thanks.
1996 Seville STS
Patch it. I used the same sort of tape that Ranger suggested. It was rain gutter/roofing sealant tape that was aluminum on one side and sticky sealant on the other. The roll was about 6" wide, so I cut a piece to wrap from the top down to the front of the housing. I did that 2 or 3 years ago and it's still going strong.
2000 ETC
If the evaporator cover is destroyed, could fumes from the engine enter the A/C system? Mine is crumbled and I have taped it up the best I can but I get oil fumes into the interior of the car.
Yes. Hot engine smell and, if you have a slight cam cover weep, oil cooking off the rear exhaust manifold will most definitely get into the HVAC ducting.
1996 Eldorado
It would be better to replace the box but I chose the tape it up with foil duct tape & spray a couple of coats of truck bed liner on it.
It actually worked out good & I still anticipate replacing the cover. More broke away when I replaced the heater core hoses last week.
You would think a plastic cover like that would hold up better to age.
2010 DTS
Johnny, I'm not sure those are even available anymore. I seem to recall someone having this problem quite some time ago and could not find one anywhere. Discontinued part.
99 Cadillac DeVille Concours
I thought I replied to clarkz71...I know it's been a while since you posted this (clarkz71); do you still have it available? You can also direct email me at gogatorswdc at g mail dot com. Thanks.
1 - 14 of 14 Posts
