I've got the aftermarket RKE. Programming requires grounding the black wire in the trunk pull-down. How do I locate this wire? :hmm: Is it on the deck lid? Or is it on the bottom, near the spare tire well? :hmm: Does it require removal of the "carpet" for access? Where do I grab a suitable ground to short the wire? I'm sure this has been covered before, any help is appreciated. I have downloaded and read the directions posted here, just not sure where to find the wire and a good GND. Had intended to do this myself, may end up at dealers anyhow...
Thanks!
~GiG~
94 Eldorado, and a 99 ETC
The wire is located underneath the plastic trim on the bottom. It looks like it should be plugged into the trunk pulldown motor but it shouldn't. As for a suitable ground, thats going to be the hard part because everything is painted and insulated in that area. You might want to try getting a length of wire and run it over to where the antenna motor gound wire is.
Hope this helps.
Re: 95 Eldo RKE - Black Wire - Got-R-Done!
Thanks, Krash!
Right on, took 5 minutes. :thumbsup:
Found GND where the deck lid rubber bumper had worn the paint off the body a little. Works like a charm. You the man :rolleyes: !
