1 - 18 of 18 Posts
My 95 Cadillac DeVille why on the interstate all of a sudden lost power started stalling in backfiring it wouldn't die but when I let off the gas and push it again it done nothing not rev up not anything just more backfiring after about three or four minutes it straightens itself out and takes off and then it'll be about a week or so before it does it again this last time it done it bad and blew the muffler open also each morning when I started up I have to rub the engine up for like 5 minutes before it idles I only use high grade has the person who had it before me replace water pump and s few other parts
593003
You can start here and see where that leads you.
Discussion Starter · #4 ·
So I ran the codes on my Cadillac through the onboard dash monitor system and it threw a ro26 and a to37 as active and then it's through a r025 in the past a p o 52 and a po25 but I cannot find what that means anyway
Also io52
Proof reading before you post will keep us less confused.
Oh yea, Welcome. Nice lookin' sled. Get those codes, lets fix a car.
TO37. RO26 ACTIVE IO52 PO25 PO52
And that's man
Forget the preceding letters and there are no "o" or "0" characters before the two-digit code numbers in these code lists.
From Post #6 - I Googled it for you.
Discussion Starter · #9 ·
So does the letters before the numbers not matter?
Because I googled it to but there is no R or T letters before the numbers so I figured it wasn't the right one
'93 SedanDeville 60 Special
Hmmmmmm - - - Looks as if the 4.9 or mid-'90s Deville series has its own code definitions???
Starting in 1994 GM started migrating from OBD-I to the EPA mandate for OBD-II of 1996
GM took certain models and began that process in 1994
Good example the 1994 C4 ZR-1 still used a ECM with a memcal and E-prom where calibration is
BUT all other Corvette models for that year were now with a PCM (flash memory) and all OBD-II codes
That made it worse both PCM and ECM based Corvettes in 1994 used the 16 pin DLC for OBD-II even though the ZR-1 still had a ECM
I suspect anytime the DTCs start with a P, that is OBD-II but again real murky in 94-95 which each model had.
Discussion Starter · #14 ·
Forget the preceding letters and there are no "o" or "0" characters before the two-digit code numbers.
Thank you so much I've now figured out the problem y'all are the best
P025
Ignition control module (ICM) -24X signal circuit malfunction
Wiring open circuit/short circuit to ground, ICM, ECM
P052Engine control module (ECM) -memory resetBattery disconnected, wiring
Listed for 1994-95 Deville
Engine DTC codes
Do you know what R026 and T037 are
Here is the old OBDI list I could not find by Anthony w. Haukap that includes the codes you are looking for.
GM OBDI Diagnostic Trouble Code List
Instrument Panel Cluster (IPC) Codes
Code Description
I022 .............................................. Panel Dimming Switch Pot Circuit
I027 ........................................................ PRND321 switch failure
I032 .......................................................... Loss of ABS/TCS Data
I033 ................................ Loss of Supplemental Inflatable Restraint Data
I034 ........................................ Loss of Powertrain Control Module Data
I037 ...................................... Loss of Air Conditioning Programmer Data
I039 .......................................... Loss of Road Sensing Suspension Data
I041 ....................................................... Battery Voltage Too Low
I042 ...................................................... Battery Voltage Too High
I052 ....................................................... Keep Alive Memory Error
I056 ......................................... Instrument Panel Cluster EEPROM Error
Antilock Brake System (ABS) Codes
Code Description
T021 ................................................... RF Wheel Speed Sensor Fault
T022 ......................................... RF Wheel Speed Sensor Frequency Error
T023 ........................................ RF Wheel Speed Sensor Continuity Fault
T025 ................................................... LF Wheel Speed Sensor Fault
T026 ......................................... LF Wheel Speed Sensor Frequency Error
T027 ........................................ LF Wheel Speed Sensor Continuity Fault
T028 ............................................ Wheel Speed Sensor Frequency Error
T031 ................................................... RR Wheel Speed Sensor Fault
T032 ......................................... RR Wheel Speed Sensor Frequency Error
T033 ........................................ RR Wheel Speed Sensor Continuity Fault
T035 ................................................... LR Wheel Speed Sensor Fault
T036 ......................................... LR Wheel Speed Sensor Frequency Error
T037 ........................................ LR Wheel Speed Sensor Continuity Fault
T041 ................................................... RF ABS Valve Solenoid Fault
T044 ...................................................... RF TCS Pilot Valve Fault
T045 ................................................... LF ABS Valve Solenoid Fault
T048 ...................................................... LF TCS Pilot Valve Fault
T051 ................................................... RR ABS Valve Solenoid Fault
T055 ........................................... LR Valve Solenoid Valve Fault (TCS)
T055 ................................... Rear Valve Solenoid Valve Fault (Non - TCS)
T061 ...................................................... Motor Pump Circuit Fault
T063 ............................................................. Valve Relay Fault
T067 ...................................................... Brake Light Switch Fault
T071 .......................... Electronic Brake and TCS (EBTCM/EBCM) Internal Fault
T072 ........................................................ Serial Data Link Fault
T073 .......................... PCM - EBTCM/EBCM Pulse Width Modulation Signal Fault
T083 ......................................................... Brake Fluid Level Low
Supplemental Inflatable Restraint (SIR) Codes
Code Description
R014 .......................................... Dual Pole Arming Sensor Disconnected
R015 ................................... Passenger Initiator Circuit Resistance High
R016 .................................... Passenger Initiator Circuit Resistance Low
R017 .............................................. Passenger Initiator Circuit Open
R018 ....................................... Discriminating Sensor Interconnect Open
R019 ...................................... Passenger Initiator Circuit Voltage High
R021 ...................................... Driver Initiator Circuit Resistance High
R022 ....................................... Driver Initiator Circuit Resistance Low
R023 ......................................... Driver Initiator Circuit Voltage High
R024 ................................................. Initiator Circuit Voltage Low
R025 ........................................... Initiator Circuit Short to Ignition
R026 ................................................. Driver Initiator Circuit Open
R028 ................................................ Current Sink Or Source Failure
R031 .......................................... Driver Loop Energy Reserve Feed Open
R034 .................................... Dual Pole Arming Sensor Ignition Feed Open
R035 ......................................... Discriminating Sensor Open or Missing
R036 ....................................... Passenger Loop Energy Reserve Feed Open
R042 ............................................... Loop Energy Reserve Voltage Low
R043 ........................................................ Driver Source Feed Low
R044 ..................................................... Passenger Source Feed Low
R051 ........................................................ Frontal Crash Detected
R052 ................................................................ Data Area Full
R053 ............................................... Driver Side Low High Resistance
R054 ............................................ Passenger Side Low High Resistance
R055 .......................................................... DERM Incompatibility
R061 ................................................. SIR Indicator Circuit Failure
R062 ....................................... Redundant SIR Indicator Circuit Failure
R071 ............................... Internal Diagnostic Energy Reserve Module Fault
R075 ........................................................... Internal DERM Fault
R081 .................................................... Driver Ignition Diode Open
R082 ................................................. Passenger Ignition Diode Open
R083 .................................................. Driver Reserve Diode Shorted
R084 ............................................... Passenger Reserve Diode Shorted
Air Conditioning Programer (ACP) Codes
Code Description
A010 ............................................ Outside Temperature Sensor Circuit
A011 .......................................... High Side Temperature Sensor Circuit
A012 ........................................... Low Side Temperature Sensor Circuit
A013 ............................................. In-Car Temperature Sensor Circuit
A015 ....................................................... Sun Load Sensor Circuit
A037 ......................................... Loss of Instrument Panel Cluster Data
A040 .......................................... Air Mix Valve (Door) Circuit Problem
A046 ........................................................ Low Refrigerant Charge
A047 ........................................................ Low Refrigerant Charge
A048 ...................................................... Low Refrigerant Pressure
A049 ........................................... HVAC - Coolant Temperature Too High
A050 ........................................... HVAC - Coolant Temperature Too High
A052 ....................................................... Keep alive memory error
Traction Control System (TCS) Codes
Code Description
T067 ......................... Brake Light Switch Fault (TCS Equipped Vehicles Only)
Road Sensing Suspension (RSS) Codes
Code Description
S010 .................................. Left Front Damper Solenoid Valve Short to B+
S011 ......................... Left Front Damper Solenoid Valve Short to Ground/Open
S015 ................................. Right Front Damper Solenoid Valve Short to B+
S016 ........................ Right Front Damper Solenoid Valve Short to Ground/Open
S020 ................................... Left Rear Damper Solenoid Valve Short to B+
S021 .......................... Left Rear Damper Solenoid Valve Short to Ground/Open
S025 .................................. Right Rear Damper Solenoid Valve Short to B+
S026 ......................... Right Rear Damper Solenoid Valve Short to Ground/Open
S030 ................................................ Speed Sensitive Steering Fault
S035 ............................... Electronic Level Control Compressor Short to B+
S036 ...................... Electronic Level Control Compressor Short to Ground/Open
S037 ............................ Electronic Level Control Exhaust Valve Short to B+
S038 ................... Electronic Level Control Exhaust Valve Short to Ground/Open
S043 ............................................................ Speed Signal Fault
S044 ..................................................... Lift or Dive Signal Fault
S050 .......................................... Road Sensing Suspension Module Fault
S055 .......................................... Resistor Module Short to Ground/Open
S060 .............................................. Left Front Position Sensor Fault
S061 ............................................. Right Front Position Sensor Fault
S062 ............................................... Left Rear Position Sensor Fault
S063 .............................................. Right Rear Position Sensor Fault
S064 ........................................ Left Front Position Sensor Overcurrent
S065 ....................................... Right Front Position Sensor Overcurrent
S066 ......................................... Left Rear Position Sensor Overcurrent
S067 ........................................ Right Rear Position Sensor Overcurrent
S070 ................................................ Left Front Accelerometer Fault
S071 ............................................... Right Front Accelerometer Fault
S072 ................................................. Left Rear Accelerometer Fault
S073 ................................................ Right Rear Accelerometer Fault
S074 .......................................... Left Front Accelerometer Overcurrent
S075 ......................................... Right Front Accelerometer Overcurrent
S076 ........................................... Left Rear Accelerometer Overcurrent
S077 .......................................... Right Rear Accelerometer Overcurrent
Powertrain (PCM) Codes (Engine/Transmission)
Code (*) Description
P000 ................................................... Cruise Servo Apply Problem
P012 ........................................................ No Distributor Signal
P013 ................................................ Right Oxygen Sensor Not Ready
P014 .................................................. Shorted Coolant Temp Sensor
P015 .............................................. Open Coolant Temp Sensor Signal
P016 ............................................... Voltage Out of Range [ALL SOL]
P017 ................................................. Left Oxygen Sensor not ready
P019 .................................................... Shorted Fuel Pump Circuit
P020 ....................................................... Open Fuel Pump Circuit
P021 ..................................................... Shorted TPS Signal [VCC]
P022 ........................................................ Open TPS Signal [VCC]
P023 ..................................................... EST Signal problem [EGR]
P024 ........................................... Vehicle Speed Sensor signal to TCC
P025 ........................ (Ignition Control Module) 24x Reference Low Indicator
P026 ............................................... Shorted Throttle Signal Switch
P027 .................................................. Open throttle signal switch
P029 .................... Transaxle Shift 'B' solenoid problem (1st, 3rd, 4th gear)
P030 ......................................................... ISC RPM out of range
P031 ........................................................... Shorted MAP Sensor
P032 ....................................................... Open MAP Sensor Signal
P034 ............................................... MAP Sensor Signal Out of Range
P036 ....................................... EGR valve pintle position out of range
P037 .................................................... Shorted MAT Sensor Signal
P038 ....................................................... Open MAT Sensor Signal
P039 .............................. Torque Coverter Clutch (VCC) Engagement Problem
P040 .......................................... Power steering Pressure switch open
P041 ......................... No Cam reference signal from ignition control module
P041 .................................................... Cam Sensor Signal Problem
P042 ............................................... Left Oxygen Sensor Signal Lean
P043 ............................................... Left Oxygen Sensor Signal Rich
P044 .............................................. Right Oxygen Sensor Signal Lean
P045 .............................................. Right Oxygen Sensor Signal Rich
P046 ........................................ Right to Left Bank Fueling Difference
P047 ....................................................... IPC - PCM Data Problem
P048 ........................................................... EGR system Problem
P051 ................................................................ MEM-CAL Error
P052 ............................................................. PCM Memory Reset
P053 ................................................. Distributor Signal Interrupt
P055 ........................................... Closed Throttle Angle Out of Range
P056 .............................................. Transmission Input Speed Sensor
P058 ...................................................... PASSKey Control Problem
P059 .............................................. Transmission Input speed sensor
P060 ................................................ Cruise-Transaxle Not in Drive
P061 ............................................... Cruise - Vent Solenoid Problem
P062 ............................................. Cruise - Vacuum Solenoid Problem
P063 ............................................. Set Vs. Vehicle Speed Difference
P064 ....................................... Cruise - Vehicle Acceleration Too High
P065 ......................................................... Cruise - SPS Failure
P066 .................................................... Cruise - RPM Out of Range
P067 .............................................. Cruise Switch shorted at Enable
P068 .................................. Cruise Command Problem (servo out of range)
P070 ...................................................... Intermittent TPS Signal
P071 ...................................................... Intermittent MAP Signal
P073 ........................................... Intermittent Coolant Sensor Signal
P074 ...................................................... Intermittent MAT Signal
P075 ...................................................... Intermittent VSS Signal
P076 ............................................... Transmission Pressuse Solenoid
P078 ...............................................................................
P080 ............................................................. Fuel System Rich
P083 ........................................ Crankshaft to Ignition Module Failure
P085 ................................................. Idle Throttle Angle Too High
P086 ................................ Undefined Gear Ratio (Trans Pressure Control)
P089 ........................ Long Shift and Maximum Adapt (Trans. Pressure Control)
P090 ............................................... VCC Brake Switch Input Problem
P090 ....................................... TCC Brake Switch Input Circuit Problem
P091 ........................ PRNDL Switch Problem (transaxle range switch problem)
P092 ............................................ Heated Windshield Request Problem
P092 ..................................... Traction Control System PWM Link Failure
P094 .................. Transaxle Shift "A" Solenoid Problem (Vehicle Speed Sensor)
P095 ........................................................ Engine Stall Detected
P096 .................................................. Torque Converter Overstress
P097 .................................................... High RPM P/N to D/R Shift
P098 .......................................... High RPM P/N to D/R Shift Under ISC
P099 .................................. Cruise Control Servo Applied, Not in Cruise
P103 ............................................. Open Brake Booster Vacuum Sensor
P105 ................................................. Brake Booster Vacuum Too Low
p109 ................................................ Keep Alive Memory (KAM) Reset
P110 ......................................... Generator L-terminal Circuit Problem
P117 .......................... Open/Short Solenoids/Solenoid Wiring (Transmission)
P119 ................................................ Open or Shorted Fuel Injector
P132 ............................................... Knock Sensor Circuitry Failure
p137 ......................................................... Loss of ABS/TCS Data
(*) for the 1992 model year only, the "Pxxx" (Powertrain) is replaced by
an "Exxx" (Engine), but the description remains unchanged.
--PCM Data Displays DESCRIPTION
The Powertrain Control Module (PCM) Data selection allows viewing of inputs the PCM uses to control powertrain functions. Each data parameter is displayed on the Driver Information Center (DIC) in appropriate units. The values displayed are non-fail safe.
PD01 TPS (Throttle Position Sensor)
PD02 Manifold Absolute Pressure Sensor in Kilo Pascals (kPa)
PD03 Barometric Pressure in kPa
PD04 Engine Coolant Temperature (ECT) sensor in degrees Celsius
PD05 Intake Air Temperature (IAT) sensor in degrees Celsius
PD07 EGR Pintle Position
PD08 Spark Advance in degrees Before Top Dead Center (BTDC)
PD09 Ignition Ground Voltage
PD10 Fuel Pump Feedback Voltage
PD11 Engine Speed in revolutions per minute (rpm)
PD12 Vehicle Speed in miles per hour (mph)
PD13 Pintle Position
PD15 Ignition 1 Voltage
PD16 PCM Output Fault Status A
PD17 PCM Output Fault Status B
PD30 Front Bank Injector Pulse Width in milliseconds (ms)
PD31 Rear Bank Injector Pulse Width in milliseconds (ms)
PD32 Front Oxygen Sensor Voltage
PD33 Rear Oxygen Sensor Voltage
PD34 Front Oxygen Sensor Cross Counts
PD35 Rear Oxygen Sensor Cross Counts
PD36 Front Short Term Fuel Trim
PD37 Rear Short Term Fuel Trim
PD38 Front Long Term Fuel Trim
PD39 Rear Long Term Fuel Trim
PD40 Knock Sensor Spark Retard in degrees
PD41 Knock Sensor
PD42 Octane Level of Fuel will display 0, 87, 90, or 93
PD69 Cruise Lash
PD70 Cruise Control Feedback
PD71 Transaxle Pressure Switch
PD72 Transaxle Input Speed in rpm
PD73 Torque Converter Slip Speed in rpm
PD74 TPC Solenoid Current
PD75 Current ER
PD76 Transaxle Gear Ratio
PD77 Transaxle Oil Temperature in degrees Celsius
PD78 Transaxle Shift Adapt in pounds per square inch (psi)
PD80 Transaxle Garage Shift Adapt in seconds
PD81 Torque Converter Clutch (TCC) Solenoid Duty Cycle in percent
PD82 Transaxle Shift Time in seconds
PD83 Non-drive Wheel Speed in kph
PD84 Brake Booster Vacuum in kPa
PD97 PROM Calibration-Transaxle
PD98 Ignition Cycles
PD99 PROM Calibration-Engine
No thanks this one has my codes awsome
IIRC we went through this diagnostics protocol flap on codes back in the mid-2000s. I bookmarked this thread for future use in these forums.
I put the simple instructions in the other thread, that's why I thought he was screwing with us lol.
1 - 18 of 18 Posts
