1 - 1 of 1 Posts
1995 Deville 4.9L
I just bought a 95 Sedan Deville but I don't think the Courtesy lights are working properly. The only lights that come on when the doors are opened or the keyless entry is used are the ones in the lower front doors. There are two map lights in the front and one light over each of the back doors should these light come on as courtesy lights? The map lights can be turned on with their respective buttons however I have not found a way to turn on the rear lights even rotating the headlamp switch to the right does not force any overhead lights on. I have verified the bulbs as good so I assume there is a wiring issue but I need to know what lights should come on when the doors open.
1 - 1 of 1 Posts
