'93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
Nice buddy you have there ;-)
If he only touched the brake pads there are the following possibilites:
- He forgot to reconnect the ABS cable (my guess)
- He damaged the cables or sensor module while working
- bad luck brian strikes and your system got damaged with no correlation to the brake pads
Pull off the rear tires and check the cable. should be easy enough to find...
2000 DTS 194,000 miles, 2000 DHS 203,000 miles
I'm pretty sure that's one of the year models that when the rear caliper is rotated upwards to remove it, it pushes against the abs connector, unplugging it.
