1 - 2 of 2 Posts
95 deville 4.9L
Ok so i have a 95 dEville thatneeds new rear air shocks my question is can i use a set of air shocks from a 95 deville concours. My friend has a parts car with good air shocks but its a contours not a base modle divelle. Please help.
· Master of the Dark Art of Diagnostics
the correct rear shock for your base model Deville
is a Monroe 40046 -
the Concours model has ACTIVE/electronic suspension -
the Monroe 40018 is the correct unit -
the mounting is the same - and uses the same air line connection -
however - your car has no way to control the variable valving inside the shock -
can you install it on your car?
YES - it will fit - and you could bolt it on -
will it function properly?
YES - and NO -
the air-shock part should function properly -
the internal valving will not function at all -
I don't have any idea whether the internal valving stays in the last position it was in -
or defaults the a "soft" ride - or a "firm" ride - or somewhere in the middle -
1 - 2 of 2 Posts
