04 cts
Looked at a 95 brougham hearse with an egr valve that is stuck. Valve is located at the back of the intake manifold (looks like a son of a gun to even get the bolts out, or even see them). Valve is stuck open...diaphram is in a position where it would be with constant vacuum applied. Valve has a rod in the center that goes into the intake manifold. Concerned this is where it is frozen/stuck. Wondering if the intake manifold might have to come off to even replace it. Any tech advice would be appreciated.
95 FWB 81SDV 96 FWB 94 Fleetwood
It really is not that hard to change. I have had a few off and never ran into a problem. If I remember right its 2 nuts and a hose.. Correct me if I am wrong.
87 Brougham, 1969 Calais, 95 FWB, 07 SRX, 07 ESV
You're right. 2 nuts. It can be a little tight to get to but you should be able to do it with the correct sized wrenches. Not much room to get in there but you can get a bit of a turn each time.
You can also block off the EGR valve connections if you don't want to worry about it. A lot of people eliminate that system completely if the car isn't a daily driver driven in cold weather.
1995 FWB 130.*** miles
The EGR valve is the easiest part to remove on an LT1 engine. Try that on 4.9 Cadillac Engine...
1992 Fleetwood S&S Hearse, 1993 Buick Roadmaster
Oh, do I smell someone else pondering hearse ownership? I sure hope so! Mine has been so much fun to own so far. It's a 1992 Fleetwood with the 4.9. I hope you get it!
2014 ELR
It's really easy to change. Easiest with a ratcheting box end wrench. No need to take intake (or even the plastic resonator) off. 10mm, IIRC.
HOWEVER, confirm it is a bad EGR, and not a stuck EGR solenoid!
