So I noticed a little anti freeze on the floor of the carport and my coolant level low notice came up on my information window.
I looked around with my flashlight and I noticed that there is some green fluid on a wire bundle under where I think the water pump is. I have not removed the air cleaner and the front left cross bracket yet which will give me better access to this area for inspection but could someone tell me if that is most likely what is leaking? And it is not under a location where there seems to be any hoses. I can barely reach my fingers back under there to see if I can find a leak location but I have had water pumps leak out of pressure holes and around seals before so that is what I am thinking this is. Does anyone have any thoughts? Thank you!
