1 - 2 of 2 Posts
none
I pulled up three codes that I cannot identify. Need Help. Codes are T033,
SO17 and S073. I believe the first has something to do with transmission, and the second maybe the MAP sensor. I'm not sure about the third. Can anybody help. Thank you.
2010 DTS
Decipher codes here.
http://myweb.accessus.net/~090/dtcobd1.html
T033 ........................................ RR Wheel Speed Sensor Continuity Fault
Wheel speed sensor is bad. You have to replace the hub & bearing assembly which contains the sensor.
S073 ................................................ Right Rear Accelerometer Fault
S017 - RF Damper Solenoid Open Circuit
1 - 2 of 2 Posts
