Screwed up my Rear Disc Brakes!! Help!!
:bonkers: Okay I replaced my rear disc brakes, rotor and pads today. It is a '94 Seville with ABS. Well I managed to put one pad on backwards on the inside of the passenger rear. On my test drive it was grinding very badly and I could not figure out what it was. I took the wheel off, and removed the caliper bolt and swung the caliper up out of the way and figured out that the back of the inside pad had put a couple of small grooves in the rotor. The pad was not in that bad of shape since I had only driven it a short distance so I reversed the pad and re-installed it correctly.... sheesh... first time for everything I guess. Anyway I was planning on biting the bullet and picking up a new rotor and pad set tomorrow just to fix this or I guess I could take the time to take it off and take it down to a local machine shop and have them turn the rotor
My problem now is my Anit-Lock brake light is on permanently and my Traction control is off since the ABS is not working. Looking in my trouble codes I have a new code T033 which relates to a RR Wheel Speed Sensor Continuity Fault. How do I fix that?trouble codes. IS there anyone out there that can help me? Should I replace the rotor and pad? Or just have it machined? Or is the fact that I did this what caused my ABS light to come on?!? Thank you for any help with this!:bonkers:
