1994 Fleetwood Brougham
Did some searching around and it sounds like the flasher relay thing is probably the cause, but figured I'd ask for feedback in case I'm wrong. Basically the other day I started hearing a fast clicking noise (or the noise of something shorting maybe?) coming from I assume the steering column when I was using the turn signals. They started to glitch a bit and stop flashing after a few seconds. Now they don't flash at all. The front side highbeam lights still activate but nothing else happens.
So would this be the turn signal flasher or a problem elsewhere?
87 Brougham, 1969 Calais, 95 FWB, 07 SRX, 07 ESV
yeah probably a bulb if you're lucky. It's the most likely cause and cheap/easy to check and fix.
Bulbs all looked good but I might check again. The local parts store didn't stock the flasher so I've already got it on order.
Thanks, replaced the flasher and everything works great. That is a very uncomfortable repair job...
1996 Cadillac Fleetwood Brougham
That's cracking great news
