94 fleetwood brougham
Hey Guys,
my 94 FWB got it's ignition stuck in the lock position. I tried both sets of keys. The ignition turns forward and back to accessory, but does not start or release the steering column lock.
Any thoughts???
Thank you,
Nick (aka bmwnick)
84 Coupe w/500
have you tried turning the wheel as you turn the key? This happens to mine, especially if the wheels arent straight, pressure on the steering lock mechanism.
95 triple black fwb
sounds like something broke ar is stuck
havent seen you around the forum lately
maybe its the name change
I have a beige column if you end up needing one....Jim
1995 FWB 124,*** miles
There is an aluminum 0-shaped part inside the column which transfers rotation of the key to the ignition lock by means of a rod. That aluminum part is known to crack and later fall apart. Disassembling the column to replace that part is a headache.
2011 Escalade ESV
That picture has now caused me to develope a wet spot. Those wheels would look sharp on my Goldie. VERY NICE RIDE! Sorry for the thread jack but it had to be done.
