Okay guys I've looked through the Forum as best as I could and didn't find anything regarding my issue so here it is
I have a 94 deville 4.9L it will not shift I have to ship the vehicle manually but here's the catch it will not shift manually or start out in low gear I have 2nd 3rd and Overdrive
Okay so this is what I've done to try and figure out what's wrong with this amazing vehicle
First thing I did was plugged into the OBD one and there are 0 codes for the transmission. Only one I got was regarding the EGR valve and I knew that was going anyway.
So because the car isn't throwing any codes I started going to the fuse box thinking that maybe there's a fuse blown somewhere and that's causing an issue don't have any blown fuses. heard on another forum the plug on top of the transmission underneath the air box can get corroded and cause a shifting issue so I cleaned the that plug no change.
And because there were no codes thrown for the transmission that tells me the shift sensors solenoids are not bad therefore I've come to the conclusion that I may need a new transmission
My next question is does anybody know if the 4t60e trans can be swapped with other gm models eg. Buick or Pontiac
as all of us Cadillac owners know as soon as you say Cadi the price triples
At this point I'm dumbfounded not sure whether I should invest in either a new transmission or just a sh** can old girl
