1 - 2 of 2 Posts
Bought a Lac '94 4.9 from a friend, its missing the line from the accumulator to the condenser, missing for some time I know dirt got into the system don't know if that's a problem. Do I need a new accumulator or would it be a good time for a r134 conversion and if so what do I need for the complete conversion? How do I know if I have the heated front windshield? Currently cracked and needed replaced but there is a $400 difference between a heated and non-heated, if it is heated can I get away with a non-heated replacement? Can't find a CAI system for the ride probably don't make one has anyone built one yet? What years of different cadillac front and back seats will fit?
2010 DTS
Dirt in an A/C system is a big problem. If there is dirt in it, it must be flushed.
http://autoacrepairs.com/134aConversion.htm
If you have a heated windshield (doubtful) you'll have a switch to turn it on. You can also plug your VIN into the VIN to RPO converter sticky and it will tell you what options you have.
1 - 2 of 2 Posts
