1 - 10 of 10 Posts
'93 STS (sold), now looking for a CTS Wagon soon!!
Everything was just fine....... Then I started my car & the blower went on for a second, then off for a second, then on for a second....then off.....and stays off. It won't come on again.
The A/C works, & I listened, and heard the vacuum doors working inside the dash, but just no air being pushed through the vents. At 65MPH, there is vent air coming through.
I searched the old posts, and the one thing I didn't find an answer to, is if there is a simple fuse or relay to the blower, before I dig further.
I think, the module is located on top of the blower housing? Is that the second thing to check?
I can't figure out the codes, but it seems there isn't a code for a blower not turning on?
What is the first thing to check if the blower doesn't turn on?
( '93 STS )
Check the connector on the blower motor to see if it looks burnt. Wiggle it and see if that gets it to work. Most likely the blower took a dive.
If that is the case, I have to remove the coils, etc., & tilt the engine forward & look for a new blower.......
What, again, is the website for GM parts...... Uh, GM Parts Direct? I thought they were off-line for a while?
Sedan de Ville, CTS
Discussion Starter #8
That would be my concern as well.
I did beef up the blower housing before I installed the North*, maybe I'll have better luck ......
I'll take photos if I actually have to do it..........
Discussion Starter #9 (Edited)
Here is the evidence.... you were correct.
Opening the housing & replacing the motor will not be that bad...just some patience.
I wonder if I can get an AC Delco motor at an autoparts store, verses waiting for one in the mail.... I'd like to do it this weekend.
Thanks, Ranger.
That is a pretty sure sign that the blower id bad. Order it from Rockauto and you'll have it in a day or two. I think they also have the plugs to replace that one. I ordered a multifunction (turn signal switch) for my daughters '04 Grand Am at about 10:00 in the morning and had it delivered the next day by noon.
1 - 10 of 10 Posts
