have you changed the fuel filter?
my camaro did the exact same thing - the old car dealer changed everything out (including the fuel pump) but left the old filter. Got it for cheap, changed the $10 filter, good as new.
Upon reviewing your codes, I would remove the top cover of the intake (8 bolts around the perimiter, I think, maybe 10, NOT the 4 recessed ones), and replace the map sensor. Be sure to check the wiring for any knicks, and the connector for any crap as well.
With that code 71, I'm surprised you didn't start there.
I also looked at your other thread, and you mentioned it had a code 70 (TPS intermittant) as well. That's not surprising, considering the criteria for that code to be set. Basically, it will set a TPS code if it sees you open the throttle, but the MAP sensor doesn't follow it (i.e. it's broke).
