21 - 30 of 30 Posts
1993 Cadillac Eldorado Touring Coupe
Discussion Starter · #24 ·
so i haven't driven the car in over a month, i found sensors locally but didn't pick them up yet because someone mentioned that it could be the ignition control module. theory is when it gets warm it cuts out and the ecu shuts down everything. this thing is really expensive so i hope it's not the problem, but could it be? i don't want to spend over $100 on cranks sensors and have it not even be the problem.
also are there any N* specific forums out there?
thanks!
2000 deville
I was having the same problem with my 00 deville. It would shut down at the worst times turning around corners etc. I did a seafoam treatment and replaced the iac and haven't had a problem since. I also wasn't getting any codes.
Discussion Starter · #29 ·
So ya i hope people can find this if they have the same problem as me as the search engine on this site is terrible. Anyway to finish this thread off unlike many threads on this forum (atleast in the N* areas), the car finally threw a code, P032, typed that into the search and BAM i get people describing the same problems as me, now you would think in all of the searches i did describing my symptoms id come across that it it just may be the map sensor.... SO it was the MAP sensor and it is fixed and running fine. I hope this is usefull information to someone out there.
21 - 30 of 30 Posts
