I have a 93 brougham that will not start. I replaced the rotor and cap and because the caps was bad. The car ran great for a week and now has the same symptom. Won't start and no spark. I don't have a spark from the ignition coil. Does this mean the the coil is bad or possibly the ignition module. I measure 12v output from the coil with just the ignition in start. When I crank it the voltage dropped to 9.6. I'm not a good car mechanic so any help would be appreciated.
Its possible for either the coil or the module to go bad. Check the coil by Ohming it out. To do this, you need a Multi-meter of some sort. Disconnect the wiring connectors from the coil and connect the multimeter as described below. The Specifications are:
Positive to coil frame- infinite
Positive to negative- 0.3-0.5 ohms
Positive to secondary output- 7000-9000 ohms
Thanx, I was ready to make those resistance checks. In look ing at the module, coil, and cap relation I trying to figure out if the module is responsible, via its internal switch, to turn on the secondary voltage in the coil or not. My thinking is that if I don't have a spark from the high end on the coil then the coil is not stepping the voltage up, or is it that the module did not gate it.
Made the resistance measurements and all were in spec. Replaced the ignition module and she started right up.
Glad to hear she's back on the road. :thumbsup:
