Hello to all! Ive got a 93 Deville 4.9 that cranks but will not start and stabilize, and heres the part i dont get, if you depress throttle about 1 to 2 inches it starts fluttering like it wants to start, but never stabilizes, if you let off throttle completely, or push past the 2 inch mark it just blankly cranks, no sign of firing... the only code that is being thrown reset after reset is code E053 (distributor interrupt) now, the things i have done to try to fix, air/fuel filters, cap/rotor, i took the ICM out and had that bench tested (turned out good) had coil tested (checked bad with high resistance and replaced) im hitting a brick wall here guys, can anyone point me in a direction that might get this old girl running? oh also, when i pulled the ICM the connector shell broke and i would like to make sure that i have all 6 of the wires on the right pins in the right order...does anyone have a few mins to pull their cap and tell me the order of the wire colors on the ICM? thanks for all your help!! -Paul
