Any codes stored?
I don't know how to ckheck for codes, but the message center says all systems are OK. The light just won't stay on when I first turn on the ingnition, something in the lamp check circuit probably. Is there some lamp driver that's failing? How difficult is it to change the bulb? I could swap it with another indicator lamp and see it that changes anything. ThanksAny codes stored?
Thanks, I'm with you but I couldn't convince the technician that it's correct. It may always have been this way. Maybe I should try a different Smog Station.I have 4.9L 93 seville and the check engine light does the same quick on off flicker, and I have no problems with emissions test. Since they don't scan pre 96 models, why does the service engine light matter at all. You passed plain and simple. Maybe those years all do that same quick flash thing. I hope I shed a "quick flash" of light on the subject.
