Have a 92 Fleetwood (FWD 4.9l), that usually works fine, but on occasion, it'll crank but won't start. With a lot of research, I've found the following:
- never a problem if it is restarted within a few minutes of shutting off.
- usually not a problem in the morning
- problem most frequent after 20 minute of shut off our sitting in the Sun
- if it won't start street a number of cranks, waiting 20-30 minutes will enable a start
- have gotten it started with starter fluid
- have replaced fuel tank, pump, filter, pressure regulator.
- tps, throttle all checked, tuneup done with plugs, wires, distributor
- fuel pressure at 43psi, regulator wool pull it down to 39
I suspect it's starved for fuel when trying to start a partially earn engine.
If the block is hot, it will start, if the block cools down but water temp is warm+, then it won't start.
It's likely a card start choke is helping to start the car under all but the warm coolant temp scenario. However, I'm not sure if this explains the waiting 20-30 minutes approach from above.
Ideas
1992 Fleetwood S&S Hearse, 1993 Buick Roadmaster
Coolant temperature sensor or ignition control module come to mind. Either could be responsible for a weak start. However, the "started it with starter fluid" part wouldn't match, so....
Sometimes I wonder if I'm helpful.
Coolant temperature sensor and MAT sensor both checked out. Tried bypassing them with a resistor to force a cold start - no change.
Control module replaced with distributor. No change.
Tried adjusting the idle position (via FDC) to totally open or totally closed (i.e. cold start choke) - No change.
Disconnected Pressure Regulator vacuum hose thinking the starting process might have have created extreme vacuum - No Change.
1985 Sedan DeVille
These are symptoms of a leaking injector flooding the intake and/or wetting a plug. Eventually it will depressurize the fuel rail and the gasoline will evaporate, then it starts fine.
'93 Sixty Special 4.9l V8, '01 Sebring Convertible, '13 300C
Had similar issues. My fix was a new fuel cap. the valve on the old had gone bad. easy to test out too: open up the gas tank when it happens. If the car starts: new cap for 3 bucks.
