73 & 74 Eldo Convt, '93 Fleetwood Hearse, '86 Fleetwood Limo
I bought a 1992 Eldorado with the 4.9.
It has 50,000 miles, the car just runs beautiful. No leaks, no hiccups.
But I can't get it to pass smog. I've replaced a lot of parts and had the car serviced. It passes as high RPM, but runs a little rich at Idle. I'm very frustrated, but I don't want to give up on it.
The shop I had the work done at suggested I replace all of the injectors, but it doesn't seem to have a problem at all.
Any help and suggestions would be greatly appreciated.
Have the car scanned at any parts store. Post the found OBD1 trouble codes and their definitions here.
Stop throwing parts at it.
Welcome to CF !!!
Welcome to CF !!!
It's not pulling any codes, no warnings. Nothing. The place I took it to was completely dumbfounded.
Best to cut my losses at this point?
Post the smog test output for idle and high rpm.
Use the onboard diagnostics and post sensors, 02 voltages and fuel trims at idle and high.
Let us know which parts are replaced and released.
2010 DTS
Just a shot in the dark, but check to see if the EGR tubes down in the TB bore are carboned closed.
Auto part Wheel Tire Automotive wheel system Rim
Another shot in the dark:
Original 4.9 fuel injectors are problematic. One might be leaking causing richness at idle. At hi rpm, the fuel trim is able to compensate.
