1 - 10 of 10 Posts
91 ETC, 91 STS, 98 Eldo Convertable, '93 Seville
Been chasing this for a while and cannot figure it out.
After I've been driving the car for a while it will not crank. I've ruled out the passkey. I can start it if i jump the starter solenoid with a screwdriver, which led me to replace the starter enable relay and still symptom.
I'm at a loss anyone have insight into this?
Starters that are on their last leg, don't like heat. Is there ANY noise when you try to start it hot?
2010 DTS
Replace the starter solenoid. When it gets hot the contacts expand and open the circuit. When it cools down they contract and close the circuit again. Remember, it's tucked in right under the exhaust manifold.
91 is still 4.9. Probably the same problem just easier to get to.
2011 Crown Vic LX, 2009 Chevy Malibu 2LT
Even better, you can replace those copper contacts for about $2 without replacing the entire solenoid. They are usually readily available
Discussion Starter #9
Not the solenoid, as i jump the contacts with a screwdriver and it starts no problem, starter has been replaced.
Did some more investigating and the enable relay does not click when it won't start so im thinking something upstream, ignition switch maybe?
Discussion Starter #10
Turns out the ignition switch. Swapped it out and cracked it open to find the contacts all burnt up.
1 - 10 of 10 Posts
