The car just had aftermarket struts placed on it. Dealer thinks the problem is fixed but light just needs to be reset. Any thoughts? Thanks
CCR =Computer Controlled Ride. If you put in aftermarket struts it will set this warning since the computer cannot control the struts. There should be a bypass kit or method.
1993 Eldo 4.9 66K miles
This is part of a bulletin covering eliminating the message in various models. HTH
  • 1991 Eldorado and Seville with Computer Command Ride (CCR): Refer to the Service Manual page 8D-12. Set the BCM override value BS09 to 0 by using the warmer and cooler buttons. Store this value by pressing the Econ button on the climate control panel and the Instant Econ button on the Fuel Data/Drivers Information Center for about five seconds. The new value will be stored even through the indicator does not flash. Remove the key from the ignition. Disconnect both battery cables from the battery. When both cables have been disconnected, touch the ends of the cables together and hold for five seconds. This will discharge the capacitors in the system and allow the system to perform properly when the battery cables are reconnected. Advise the customer they will have to reset all radio stations and clock.
