2018 Mazda 6 (Venus) 1964 Impala (Betty) 1991 Miata (Dolly)
My 91 DeVille stalls repeatedly, and it's driving me crazy. I have replaced all the fuel injectors with new ones from Fiveomotorsport, and because I was getting a code E41 (Cam Sensor Signal Problem), I put in a new camshaft position sensor. And it still stalls!
I cleared the codes after replacing the cam sensor, and after this morning's latest batch of stalls, I ran the diagnostics and have the following codes:
E12 - No Distributor Signal
E53 - Distributor Signal Interrupt
The car will generally stall when coasting down from speeds above 45 MPH. I drive a two-line state highway about 15 miles, and the car tends to stall when I'm slowing down as I get into town. Last night, it stalled as I slowed down to turn into my neighborhood (I've gotten adept at making turns without the benefit of power steering). This morning, it took several tries to get the car started, and it smelled like the engine was flooded, which I know is impossible with fuel injection. But it was that rich gas smell.
I've already had to be towed home once (thanks, AAA), and I'm afraid I'll get into an accident if this continues.
Stoney, Sal, Sandy, Blaze, anybody — help!
Something else to think about: When I had the distributor cap off, there was a brittle, broken piece of plastic loose, which I removed. I think it is part of the ignition control module. The wires appeared to be OK. Could that part be the cause of the problem?
