I got a 91 Deville and the Service Engine Soon Light came on yesterday and i pulled the codes
by following the instructions i found on this forum and i got these :
E040 Power steering Pressure switch open
E052 PCM Memory Reset
E090 VCC/TCC Brake Switch/Park/neutral switch Input Circuit Problem
How can i fix these problems or clearr the coddes? The car from time to time feels like its going to stall when im just cruising or on a stopp.
2010 DTS
Sounds like a bad switch. R & R (remove & replace)
Pulled battery power lately?
This switch is at the top of the brake pedal. Not sure if that code is indicating a bad switch or not.
'87 SDV
To clear ECM codes: Enter diagnostics, let code cycle run until .7.0 appears. Press OFF and HI simultaneously and hold until E.0.0 appears. Exit diagnostics.
To clear BCM codes: same as above, just hit OFF and LO instead until F.0.0 appears.
This doesn't solve the problem, it merely clears the codes. Exisiting problems will just reset the codes in time.
