91 DeVille Parking brake release, Question!
My Current Problem is HERE
My deville does something funny, The electric door locks will not work when a door on the vehicle is open.
If I open the driver side door and push the button to lock the doors, nothing happens.
But if the door is closed and I am inside the vehicle, the lock button functions normally and locks all of the doors.
Is there any way to fix this? Any suggestions?
This was fixed, Thanks Chris!
Dumb question, but is the key still in the ignition when you try the door locks?
It doesn't matter if the key is in the ignition or not it sohuld still lock. Does the lock button on the other door work properly?
Discussion Starter · #4 ·
No, the key is out of the ignition when I try the door locks.
Nope, both doors will function when they are closed, however when they are open, the lock button does nothing.
Is it possible that there could be a problem with a fuse?
Yes, it is likely a fuse problem. The fuse that is the likely culprit is on the passenger side - you'll have to remove the lower sound insulator the get at it. It is located in the relay center. power door lock fuse is # 2.
Had the exact same problem when I bought the car.
Regards,
Chris
Discussion Starter · #6 · (Edited)
Regards,
Chris
Thanks allot Chris! That was the problem, fixed it in about 5 minutes.
Now another question, HERE
