2 issues
antilock brake light stays on all the time. Brakes/lines were replaced last year.
Check eng light goes bonkers every so often when driving along with the MPG/gas consuption panel lights (at the same time). Have not checked the codes to see if any show, can't remeber the exaxt buttone to hit on the panel to show if any codes show up.
any ideas what to look for or change?
Unicycle
antilock light means there is something wrong witht he ABS systemn, could be a sensor or anything.... I would get it check out...warning, when antilock light is on, the car is running in "regular brake mode" so you will not get the benifits of ABS
to get codes press OFF and WARMER, hold them bth for a few secs.... on the FDC IIRC .7.0 will display then any codes.... when you get the codes, I have the factory service manual, so let me know and I will tell you, or go here:
(ps, on this site, P and E are the same thing)
http://209.145.176.7/~090/awh/dtcobd1.html
The codes i get are E30,E39,E98
93 Fleetwood RWD, 99 Deville
Does the anti-lock light come on when you first start the car or does it wait to come on when you start moving.
Blaze
