91 Deville, Air blower motor will not turn off
2410 Views 3 Replies 3 Participants Last post by  slyone
Hi,
Turned off car today and found that I cannot turn off the blower motor. When the engine was shut off the blower kept running. The air was comming out the bottom by your feet. No error codes. Removed 2 different fuses relating to air / heat under the dash and still it keeps running.
ANY THOUGHTS?
Hello...
Blower module is faulty. Part number AC/Delco 15-72530. Price in 1999 was $75...dunno what it is now. This should be a good part number for your 1991 DeVille. Install is easy...it is located under the cowl near the blower.
Well that was it. Thank you very much.
Blower module # 15-72530
$150.00
OK did some work on the 84 Deville today. Working some Heat problems out, went to do a test and start the car. To my suprise Blower on MAX Compressor on all the time will not cycle, no Display on climate control system... ANy ideas what happned??
PLEASE HELP!!!
