1 - 1 of 1 Posts
Ok so I have a 90 Seville with 125,000 miles...It's not in bad shape as we've put a lot of work into it so far. But now it started bucking, and then it stalls. It's a stall like there is no fuel being sent. We had the pump tested and it is running fine. After that we replaced the fuel filter...No good..We then replaced the cap, rotor and the module inside it....No good....We checed the pickup coil....It's fine....We replaced the ECM...no good...Now after replacing the ECM I am receiving two codes...E052 and E065....So as of right now we are confused and about to have it towed to the mechanic on Monday...But if anyone has any insight that would be great...Also the plugs and wires are fine...And when you start it back up...it fires right up no problem...But...it has burned 4 gallons of gas in 8 miles....You can smell it especially when you start it back up... anyway thanks to anyone who can help...
1 - 1 of 1 Posts
