Can't get under my hood!!!!!
Help
my hood release cable poped. i would like to replace it but I can't open the hood. I have tried pulling on the wire it's self but had no luck. I reoved the front grill but i have no idea on what to do next. Any one had this problem before?
1989 Sedan DeVille is now just a fond memory ....
Re: Can't get under my hood!!!!!
Please tell us the year and model of your car, that will help. if you have removed your grille and can get to the latch it should be just a matter of finding the point of connection of the cable and manually activating it.
Sounds easier than it may turn out to be I'm sure.
Good luck and let us know how you make out.
1968 SDV, 2022 CT5V Blackwing
Ugh what a project... If you can look at one in the junkyard, it might help you find where the cable is run in your car. IIRC, the latch is BEHIND the rad support, which really hinders access. You might actually have better luck going from under the car.
1989 Fleetwood FWD / 2000 ETC / 2000 STS / 2006 STS V-8 1SF RWD
Hello...
:yeah: I recommend a visit to your local Pull-A-Part yard so you can disect a hood latch there.
It won't be easy, but it can be done.
I was successful by going in from underneath (car on ramps)
when I repaired a sticky latch on my 1989 Fleetwood.
Patience...and a good flashlight are your best friends!
Other than this, I don't have any further suggestions.
Post back your solution.
