1 - 2 of 2 Posts
88 Sedan Deville, 89 Eldorado, 11 SRX, 18 CT6
Electronic Level Control module, motor, etc. on your rear passenger tire there is a sensor underneath on the suspension. this tells the relays when to add or remove air from the orig air struts which may not be on your car now. if your car was converted they usually leave the sensors and motor and hoses and just pull the fuses. under your electronic climate control there is a green light which would say car is leveling for a few seconds after you turn it on if your level system was working properly. if its constantly on, its just running pumping air into nothing, such as broken struts, or a leaking system, etc. the purpose of the fuses is that 1) if the pump is running and running and running, and the normal sensors dont turn it off after 2 minutes the fuses pop to protect the pump.
1 - 2 of 2 Posts
