Hi all,
When I first got my Brougham the power steering would squeek and be hard to turn, especially whn not moving. Usually when moving the steering was fine. When the steering dropped out I looked and saw there was no fluid in the resevoir and some obvious leaks. I found out that both the pressure and return lines were leaking (bad) so I replaced them and filled it with fresh fluid. The leaks are all fixed and car is steering well but I still, at times, get that squeek or chirp and hard steer for a second when turning the steering from a stopped position. Steering while moving is fine. Any thoughts? Thanks in advance!
-D.C.
-D.C.
