1986 DeVille / Fleetwood. I just picked up this car so i dont know much of its history other than I found a reciept that a new condensor/accumulator and recharge of 134A was done appx 10k miles ago.
when i turn the on the AC, the air doesnt get cold. Fan works lo/hi and i can bump the temp by hand down to 60*, but the air dont get cold. the fuse for the AC is good.
whats the easiest / cheapest way to diagnose why its not cold.
thanks
2010 DTS
Put a set of gauges on the service ports and get the high and low side pressure readings.
87 Deville, 4 door
I have an 87 DeVille 4 door, and my problem with the AC is lack of real air movement from the vents. Blower motor sounds powerful enough.Does yours have a good air flow out of the vents? Just curious. Sounds like your problem should be an easy fix. I am still searching for vacuum leak or problem with one of the doors that direct the air. Real Bit#ch to move around under dash. LOL.
yeah, mine blows good. are you sure you selected the "HI" mode on the panel?
2010 DTS
Check the HVAC housing on the firewall. If it has gotten brittle and cracked, then all the air is being diverted under the hood.
thanks for all the suggestions guys, but the car is gone.
i sold it as is last night.
cheers
