OK--
This is going to sound like a pretty technical question, but here goes:
I have an 85 Coupe Deville with the 4.1 motor. Car starts perfectly every time and idles just fine. Here's my problem: when the car is warm, I have a "dead-spot" in the acceleration when I push the pedal somewhere between 1/4 and 1/2 of the way down. Once I get past the 1/2 way point, I get the increase in power that I'd expect as I push it down to the floor. The dead spot doesn't exist when the car is cold...it drives just fine.
Here's what I've checked/replaced: new 02 sensor, switched the MAP sensors from a good car that I drive everyday, no difference. Fuel pressure is a constant 12psi (well in spec for the TBI motor). Car also has a completely new distributor, cap, rotor, coil, wires, and plugs (all Delco).
Here's what I've observed: my fuel injector pulse width parameter strangely won't increase when I push the pedal down between 1/4 and 1/2 way. It stays at 3.5 milliseconds that entire time (actually it seems to jump up to 3.8, then go down to 3.5 if I push the pedal down). Then, once I pass the 1/2 way point, it jumps up to 4.1 milliseconds, and keeps increasing past that point. Basically, the engine isn't getting enough fuel.
I've checked the throttle position sensor, and its voltage increases smoothly and linearly, and it DOES increase as I push the pedal through the dead zone. The MAP reading (the opposite of vacuum) also increases throughout this dead zone, so the engine is getting the right signals. My coolant temperature sensor readings seem reasonable, as do those for the MAT sensor. Not much else left. 02 sensor toggles between rich/lean voltage. I'm stumped. Misadjusted TPS, perhaps? I can't really adjust it to a higher voltage setting without creating idle coast-down problems (idle would become too low). If I adjust it to a lower voltage at idle, the car becomes more sluggish.
Any ideas?
