1 - 8 of 8 Posts
My 85 rwd has been cutting out when going up hills. this started about two months ago, and at that time i suspected the fuel filter. So I replaced the filter and all was good until now. It doesnt even start now so any info is helpfull.
94 Fleetwood Brougham
Any codes being tossed before it started cutting out?
Is it backfiring? If so, through intake or exhaust? Intake backfiring is often lean conditions or timing way off.
Since the car is carbureted, I'm going to take a stab at it being an ignition issue. Probably a coil or coil wire. The cutting out intermittently while going uphill would coincide with high-KV loads on the ignition. Check it for spark.
Discussion Starter · #5 · (Edited)
Here is some more info thanks. After it died the first time i started it up again no problem, but I had to pump the gas to get it moving. When I just pressed on the gas it would start to die again, so I pumped the gas and the it would jerk forward and then die. it continued this for about 5 minutes(starting, then dying) until it wouldnt start. It didnt show any codes when it died, but I think it has something to do with the fuel delivery.
90 Brougham 5.7, 05 Deville DTS
I had a very similar situation this summer with my 85 Fleetwood Brougham. The problem turned out to be the fuel pump. First thing to do is make sure you have gas, those fuel level guages can go out without warrning, and go from there. Good luck.
1979 Sedan deVille d'Elegance
Hello!
Just to clarify, the 1985 Fleetwood Brougham was the last year of the HT4100 engine in the full size rear drive cars. The only other optional engine in 1985 was the diesel. I'm guessing you have the HT4100, right? The 307 Oldmobile V8 started in 1986.
D
1995 Fleetwood Brougham
I had the exact symptoms with my 85. I went nuts. It would sputter under a load but idle real nice no misses. I pulled the cat, changed the cap, rotor and wires, coil... In other words spent a lot of money when i should of changed the fuel pump...
1 - 8 of 8 Posts
