1984 Eldo Cov't, 2002 ETC Conv't
I have an 84 eldo conv't. Presently I have four 215 70R 15 while walls on the car. The two fronts need to be changed but I see on door it says correct tire size is 225 70R 15. I have had the eldo for 10 years using 215's with no known problems. I have good tread on all 4 but two back are 8 years old while the two front are only 3 years old. Question: Can I just replace the two rear 215's with new 215's or do I really need to change to 225's? If I need to change to 225, can I change just the rears to 225 and keep the other two good 215's (3 Year old) and change them in a couple of years or must I change all 4 to 225.
Lastly, if I must go to 225, as I want to stay with white walls, what brands do you guys recommend or use for 225 70 R 15 White Wall. I checked with Michelin and they said they do not have 225's in white walls, only some white lettering. I'm going crazy over this. Thanks alot PS being 61 years old I am not going over 90 MPH anywhere and and drive about 3,000 miles a year on Long Island, NY Thanks again, Wally
94 Eldorado, and a 99 ETC
There is no need to change back to 225, now that you know 215 will fit. The only difference is traction. With the 215s on there you will actually get a little bit better gas milage also. Maybe not a noticable amount, but its an increase none the less. Just make sure that the new tires can handle the weight of your car. :thumbsup:
Also :welcome: :wave:
84 & 88 Elegantes, 89 Allante, 91 & 93 60 Specials
The 225s were the tires used with the "touring suspension". The 215s were the standard size.
I recently installed a set of Kumho performance whitewalls on my '85 seville and I'm extremely pleased with the transformation in ride and handling that they wrought.
