1 - 8 of 8 Posts
Hi, friend of mine has 1984 deville (with 4.1 V8) and he's trying to find a way to switch his instrument cluster to metric system.
Is it even possible? Maybe you know how :)
1996 DeVille, 1985 Brougham SAGE GREEN!
I assume you could find a Canadian-spec '80-'84 Deville or '80-'89 Brougham and swap out the speedo and stuff...
Try Ebay. Someone on here may be able to help too.
1981 Cadillac Coupe DeVille
Yeah, my 81 Deville has kph. You can try some Canadian wreckers for a cluster. Make sure you specify overdrive transmission or not as they are different.
Ohh, I didn't make it clear (you can see my english isn't the best :)
I mean the electronic display. If there is any "combo" for pressing buttons to make it show values in metric? I think it can be done in the newer cadillacs.
But thanks to both of you for help :)
Sedan de Ville, CTS
Thanks for that info! At least we can stop trying.
If you are an egg head, you could engage the standard formula for conversion. Heck, just memorize the speeds at 25 mph, 30, 50, 55, 65, 75, etc. If you are travelling at other speeds, you can alway interpolate.
Or for the mentally challenged,
Print out a conversion chart and tape it to dashboard.
Premium Member
If you get it wrong the Mounties will write out the correct number for you.
1 - 8 of 8 Posts
