741 - 759 of 759 Posts
84 Coupe w/500
Discussion Starter #741
That's sounds pretty close. They say about 20% loss thru drivetrain which would be around 420hp. The plan was to do two runs at a time and adjust timing from there. First adjustment put me pretty close, second adjustment was gonna dial me in but never made it that far. I had a lot of fun, live bands, great food, hundreds of cars, burnout contest....
02 Escalade | 02 Corvette "Goldilocks" | 03 Blazer 4x4 | 92 Caprice Wagon LS1/T56
That's pretty awesome. P.S. Have you downloaded the Chrome browser extension to get all your photobucket pictures working?
84 Coupe w/500
Discussion Starter #743
I havent. I thought you posted a link but I have safari on my apple computer. Not sure. The whole photo bucket thing just upsets me when I think about it. I took almost 200 photos this weekend, including the other brougham setup for drifting(roll cage, big ebrake, 355ci, ford 8.8, ladder bars) but haven't found time to find another host.
84 Coupe w/500
Discussion Starter #745
All back together now. I was having issues with big puddles of oil under the car after I turn it off and it turned out to be the white wrench off K&N oil filter. Not sure if it was a defect but it didnt work and was causing a strain on the oil pump and a loud whinning sound. Took it off and saw that it was collapsing. Even the metal shell started to pull inside. put a racing radiator in it, redid some wiring, got a B&M shifter, driveshaft safety loop and have a guy coming to do some custom headers.
84 Coupe w/500
Discussion Starter #746
Well yall, I'm still at it with this car. Just came from cash days a couple weeks ago where it ran its best time to date. Motor is still running really strong. I have a video but it's says it's too large to upload. It's about 50 sec long if someone knows how I can load it.
84 Coupe w/500
Discussion Starter #750
Thanks. I can get the RT down to .23ish. Running under 8 seconds now eight mile. I've been beating the camaros and mustangs but the corvettes are still a second faster. One day.
84 Coupe w/500
Discussion Starter #752
3.90, seems pretty good for eigth mile, maybe a twinkle bit too much, guessing 3.73 would be perfect for eigth. Definately runs out too fast in quarter.
2014 ELR
Damn, I was going to suggest trying 4.10s or 4.56s. I have 4.10s in my T56 car. What's your RPM through the traps?
84 Coupe w/500
Discussion Starter #754
You know, I'm not sure. And now you have me wondering if I'm going the wrong way with my gears.... I think I am. I've never thought to look down at my gauge, just by feel. I might try to get out there for one more test and tune before the year ends. Rookie stuff but I'm learning.
2014 ELR
Yes, tach time. Then look at RPM/red line in top gear, and add in the tire height, then work the calc with the gears. Lower gears will get you out of the hole.
84 Coupe w/500
Discussion Starter #758
My son turns the camera but you get the point. Going thru the traps at 6300rpm+. It was popping a little on the big end at that rpm so I wonder if I need to adjust timing a little, just a couple degrees since it was very minor. Fastest run was 12.05 @111. I think I can get under 12 if I get the timing right.
Battle of the driver. I ran an 11 tenths faster time, he had a 14 tenths better reaction. It came down to .03 of a second. His reaction time gets him the win even though I ran a quicker time, I was eliminated second round...damn
